查看: 1281|回复: 0
CF618/CF588/CF920/CF930更改液晶钥匙车标方法CF618/CF588/CF920/CF930 change the LC
发表于 2024-4-25 15:59:00 | 显示全部楼层 |阅读模式
CF618/CF588/CF920/CF930更改液晶钥匙车标方法1
CF618/CF588/CF920/CF930 change the LCD key car logo method 1
凯芙特液晶钥匙修改车标的软件和车标CF related logos and software downloads
第一步:确定液晶钥匙要有30%以上的电量
Step 1: Make sure that the LCD key has more than 30% power
CF618CF588CF920CF930更改液晶钥匙车标方法2
第二步:更改完成后,要进入液晶钥匙设置界面把BLE_OTA关闭,否则会导致液晶钥匙舒适进入功能不能正常使用
Step 2: After the change is completed, enter the LCD key setting interface and turn off the BLE_OTA,
otherwise it will cause the LCD key to enter the comfortable function and not work normally
一个图像:
GMT+8, 2026-4-19 23:51 , Processed in 0.273933 second(s), 12 queries , Gzip On, File On.
